Hi, just a quick one.
Spark plugs.
Should one buy the main dealers recommended ones, or will any motor factor place do as long as the thier book says that they are compatable?
Is thier a difference in performance between a main dealers £4.99 per plug or a motor factors £2.20 per plug.
Hope u see what im trying to get at.
Alec.
3 |
alec |
216 |
22nd July 2008 - 10:34 PM Last post by: Vtim |
Hi all again.
I do not wish to break any forum rules, so I will try and word this the best that I can.
I was searching a well-known Internet auction site today under Hyundai Trajet and came across this.
Vortex Generator - Increase your gas mileage by up to 31%!!!
For non-turbocharged vehicles it is installed in the air intake system, right after...
2 |
alec |
180 |
22nd July 2008 - 10:32 PM Last post by: Vtim |
Problem with Oxygen sensors. fAULT CODE on ECL indicates PO421 Catalyst efficiency fail. 5 Oxygen sensors fitted to my model.
Anyway of isolating the fault code to an individual sensor?
6 |
Rich T |
446 |
22nd July 2008 - 10:30 PM Last post by: Vtim |
Hi All
The engine in my trajet made a wzzzzzzz type of sound
two months ago .the sound comes from the right side
behind the front wheel . It is related to the engine speed .
obviously , I considered the timing components are the
cause . when opened the timing belt cover ,I found
out the source of sound comes from exactly the timing
belt B...
6 |
mazen |
286 |
10th July 2008 - 02:57 PM Last post by: mazen |
Hi, As I was driving a few days ago my trajet went into Safe mode(which is only on 3rd. gear). I drove home and seach in this forum and found that usually the input sensor is the problem also advice me not to drive the car. The next day I sent the Hyundai ppl to my place to check with the scanner and found error code P0755 and P0760 which is the Solenoid valve. They took out the soleoid valve and...
1 |
Explorer 1 |
158 |
6th July 2008 - 03:43 PM Last post by: mazen |
Since a while I hear at high speed (>120 km/h) a strong whistling sound. I cannot locate the exact location where the sound is coming from but is seems to come somewhere from the front window.
If I put the wipers on it disapears, so I conclude that it has to do with the airflow along the front window or the attachment of the window to the bodywork. With strong headwinds the noise...
29 |
Sparks |
2,551 |
3rd July 2008 - 06:12 AM Last post by: pvdossel |
Hi all,
My car recently having a problems. It always caused the engine to stall when moving off and sometimes when applying the brake to stop. When the car is idle at traffic light, the engine revved up and down, maximum 1500rpm and down about 700rpm and come to settle again just below 1000rpm. Anyone here ever encounter this problems.? Please advise me what caused my car engine to rev and...
1 |
Wakdinara |
134 |
27th June 2008 - 08:58 PM Last post by: trajetXG |
hello to all!!!!
are there any trajet owners here in OZ? love to hear from you guys......
thanks!!!! default/460.gif' '460.gif' />
4 |
baby spice |
321 |
25th June 2008 - 01:00 AM Last post by: Cyrus |
Hi All,
I am thinking of getting a 2nd hand Trajet 2 years old or less. The demands of a growing family...... Current ride is W124 MB
My question which I hope experienced Jetters can assist as follows :
1. Any "defects" to be aware of when physically checking (inside / outside) the Jet -
2. When test driving, any aspect to be aware of which...
23 |
vento95 |
553 |
16th June 2008 - 12:24 PM Last post by: Vtim |
Hi,
I have just come to change my spark plugs, lifted off the engine cover and I am looking at two of the four plugs that appear to be duel ignition? It’s a black plastic box, which has 12v HMC wrote on it, two bolts secure these.
Is there any consequence for removing these two bolts and lifting off the plastic box e.g. like having to put in an engine code or something like...
2 |
alec |
176 |
15th June 2008 - 04:34 PM Last post by: alec |
1) Anyone tried to install CNG on your Trajet?
2) Where to find authorised CNG dealers in S'pore?
3) Heard that LTA will refund 40% of OMV to owners who install CNG?
3 |
sth |
786 |
13th June 2008 - 01:04 PM Last post by: mmzz |
Hi
My exhaust is looking a little tatty, and I am just about to look for prices.
I dont need one just yet but I am betting one from Hyundai wont be cheap.
Can any one recommend some where that is reasonable.
I was thinking that if a trajet 2.0 gsi auto petrol was being broken for spares that a 2nd hand one would do?
Another question?
Is...
3 |
alec |
156 |
11th June 2008 - 03:40 AM Last post by: alec |
Hi,
I recently posted a newbie post and asked about Trajet error/trouble code u0d00.
Well, through a process of elimination I seem to have tracked down the fault. Whether or not this is the code for that particular fault I don't know, but the fault is fixed and all is well after a LONG trial and error day.
Fault Code (error Code or Trouble Code u0d00 was showing on...
0 |
highfield6 |
180 |
6th June 2008 - 01:58 PM Last post by: highfield6 |
does anyone know how much a replacement remote for the central locking costs ,
for ages mine would unlock the car but not lock it , I changed the battery about 3 weeks ago and after a bit of fiddling with the little terminals inside I got it to lock and unlock ,
yesterday it decided it wasn't going to do anything and know amount of connection bending would make it change its...
12 |
mickey taker |
501 |
31st May 2008 - 07:40 AM Last post by: Taxi Shaun |
my trajet 2.0l gsi petrol won't start.
broke down whilst driving a couple of weeks ago, towed home, error codes suggested cam sensor error.
saved up for new sensor but still doesn't start. Had to recharge battery as it went flat.
Immobiliser symbol fashes 5 times when ignition turned on, is this faulty?
Plugs spark and are wet.
Any help...
12 |
yogi3 |
671 |
23rd May 2008 - 12:33 PM Last post by: Hyundaiownersclub |
Greetings,
My Trajet 2.7l v6 2007 model has only done 5700km and consumption is a steady 16.5l/100km. Is this normal? City and highway driving does not make a difference.
The idle compensation increases the rev when the aircon is switched on, from about 750 to 950 rpm. Is this normal? My take on idle compensators is that it compensates so that there is no reduction in rpm,...
6 |
naidoosv |
655 |
20th May 2008 - 04:24 PM Last post by: naidoosv |
I have a Trajet and having problems with my Air Con only going as low as 16 degrees C, I have changed the filter and been to Kwick Fit and tried to get the Air Con recharged but I was informed that the temp had only dropped 2 degrees to 16 degrees. the machine detected no leaks and topped up, but then asked the machanic to top up the rear air con and he did not have a clue what this was, is there...
2 |
bigcars_0 |
256 |
20th May 2008 - 09:14 AM Last post by: weeboab |
Hi Guys, New to the board, however have had my Trajet for 2yrs now it is however 8 yrs old.
I have a problem with it and whilst searching the net for answers came across the board.
Seems to be a wealth of knowledge here so I hope you can help me out.
The story so far.(SHORT VERSION)
Parked the car on my drive as normal, came to start it a few hrs later the engine was turning...
8 |
alec |
413 |
20th May 2008 - 07:08 AM Last post by: alec |
question to everyone,
has anyone out there ever tried installing twin exhaust mufflers to a trajet? i saw this picture of a trajet with twin mufflers, 19'' wheels with low profile tyres, body kit, and it was a show car of a company called CUPER, .is that photo for real or is it just a photo chop-shop thing?
would there be any problems if i tried to install...
3 |
baby spice |
270 |
6th May 2008 - 06:21 PM Last post by: Cyrus |
can somebody tell me how hard it is to change the thrust bearing in a trajet 2ltr gsi petrol ,the car runs great but the noise is getting to me , i was going to do the clutch but its perfect , do you have to take the gearbox out or can you split it to get to the thrust bearing .and how much is a 2000 model worth as im thinking about selling it
1 |
civickits |
168 |
3rd May 2008 - 06:59 AM Last post by: montego |
I have just started hearing a sqealing noise from the steering even if i go right/left or over a bump ?
any ideas
Whiterabbit
16 |
whiterabbit |
430 |
2nd May 2008 - 03:04 PM Last post by: whiterabbit |
1 |
civickits |
166 |
2nd May 2008 - 04:38 AM Last post by: weeboab |
Hi all,
The interior fan makes a clicking noise that increases the higher the setting its put on, as if the fan blades are touching against something.
Where exactly is this fan located and is it easy to view/remove ?
Cheers,
N
0 |
nick31 |
156 |
30th April 2008 - 07:52 AM Last post by: nick31 |
Oh boy! My 2001 Petrol Auto Trajet with only 36,000 genuine Km on the clock has had poor fuel consumption since I bought it 3 months ago. A week back the engine warning light (orange) came on and stayed on. I had an ECU scan done that came up that the catalytic converter should be checked. No rush I thought - how wrong!
Today, whilst in the middle of nowhere in the hills of Sri...
3 |
borneo |
290 |
15th April 2008 - 03:47 AM Last post by: borneo |
Hi, New to Forum and am desparate for advice please. My 2001 Petrol Auto Trajet coughs, splutters and stalls after about 40 mins use. Restarts straight away but dies again after a few mins (ECL illuminated on some occasions, but not always). Garage has had it for 2 weeks now and have cleaned injectors, flushed fuel system, replaced fuel filter, spark plugs and fuel pump. ECU has been substituted...
12 |
Rich T |
677 |
11th April 2008 - 11:04 PM Last post by: borneo |
Hi,
Are there any diagrams or pictures that show how to remove and refit the center facia.
thanks
Zabs
0 |
zabs |
247 |
7th April 2008 - 07:37 AM Last post by: zabs |
Anyone having a slight flat spot/hesitation sometimes?
Never whe cold for some reason? it only does it intermitantly
2l crtd 02 plate (early model)
Checked the basics and all seems ok ,no fault codes did have problem with EGR valve a while ago and this fixed a similar problem ,this seems like a slight air ingress in the induction system but have not found anything anyone have any...
8 |
weeboab |
336 |
6th April 2008 - 06:05 AM Last post by: Rich T |
when i replace oil transmission, i broke the drain plug.
how to fix that?
4 |
liuytres |
278 |
3rd April 2008 - 02:26 PM Last post by: mazen |
Hi Peeps
i have been asked by motability (the charity they helps disabled people) would i like to lease the car for another 2 years, well er yeah to right , best car I have ever had , never let me down in 2 yrs its had a full service from main dealer from day 1 , i have had a few pwople who have asked me what the trajet is like and i cant praise them enough , mines a low milage at only...
8 |
whiterabbit |
440 |
26th March 2008 - 05:16 PM Last post by: weeboab |
