I want to upgrade my website, which is especially for the Elantra J1, but I want to invite the Excel X2 drivers as well.
Would it be possible to send mir informations, pictures aso. about the car? Maybe, you know which parts from the Elantra and Excel are the same?
0 |
lantraj1 |
130 |
30th May 2008 - 12:57 PM Last post by: lantraj1 |
One day my car just started running iradically now. It'll drive down the road just fine, but when i stop at a stoplight and idle, the oil light with come on and tends to cut out like it wants to die. Ever since this has started, it has gotten really hard to start the car. I am not sure what the problem is.
2 |
Jamebond |
612 |
17th May 2008 - 08:49 PM Last post by: ratchan |
Whenever I accelerate or slow down the steering pulls to either side, sometimes left, sometimes right. Most of the time I have to have a firm grip on the steering wheel to stop it from pulling either side. The pulling gets more pull when harder acceleration or deacceleration.
I have taken it to a workshop, a wheel & tyre place and a suspension specialist and they all think the car...
2 |
tigers4250 |
252 |
17th May 2008 - 02:51 AM Last post by: ratchan |
Hello to all. My name is Rich and I have a 93 excel that has only 24,000 miles and the car as you can guess is like new. Now, Late last year my daughter was drining it when suddenly it began to shake and knock and shut off. It would still start but would shake and knock wildly. Anyway I had it towed to my local mechanic and found that one of the rocker arm shafts had broken. He said it was common...
1 |
top gun |
265 |
17th May 2008 - 02:49 AM Last post by: ratchan |
EY ,CAN SOME1 HELP ME ! I WANA KNOW HOW 2 CONNECT A CD RECEIVER TO A 1997 HYUNDAI EXCEL ,, IM PUZZLED .................HELP ME PLZZZZZZ[COLOR=blue][B]
Help!
2 |
megii |
220 |
17th May 2008 - 02:43 AM Last post by: ratchan |
My Hyundai has had a re-occuring problem & mechanics keep thinking they've fixed it but never do. The symptoms are; I'll be driving along normally & then I have to stop at lights or a round-about, when I stop the car feels like it is 'locked-up' then I go to take off & it won't accelerate, it feels 'stuck' so I put my foot down hard & the wheels...
2 |
sprint |
306 |
17th May 2008 - 01:32 AM Last post by: tkjsprint |
Hey,
I disconnected everything on my deck in my Hyundai Excel 94 x3 last year to put a new stereo in. However, I didn't connect everything back up like the temperature controller on the fans which is getting really dangerous at the moment as I can't defrost my windows (it's becoming winter here).
Does anyone have a diagram or something that outlines all of the connections I...
0 |
bassftw |
195 |
13th May 2008 - 08:38 PM Last post by: bassftw |
Hi all realy would love some help an advice.
Just about to purchase a 1999 Excel sport, I have noticed that in 2nd and 4th gear the gear stick goes way back, close to the hand brake? All gears engage fine clutch is fine just only in these 2 gears the stick seams to go into gear then down toward the hand brake as if it were close to laying down?
Would this be the Gear box...
1 |
brooksee |
209 |
11th May 2008 - 06:43 PM Last post by: brooksee |
Dear Mechanics.
I need to pick some brain, I just had my 1990 Excel deliverd into my drive way this afternoon, got the car for free, in very very good shape. The only problem is that the existing engine is a second used engine that has a bad rod. I will rebuild the engine, but I think the newer 16 valve 4 banger could also work. I need some brain power...
0 |
The Sentinel |
212 |
6th May 2008 - 10:53 PM Last post by: The Sentinel |
G'day all!
Im new to the site. hoping some one can help!
Im wanting tighten up the hand brake on my 1999 Twin Cam Hyundai Excel.
Is the adjuster on the hand brake its self or somewhere else? I've heard some people say just to adjust some nuts on the hand brake lever its self and other refered to a technique where the hand brake is applied and the car is...
1 |
PhillMiester |
372 |
1st May 2008 - 08:52 AM Last post by: NovaResource |
Hey Guys!
I am new to your forum so please be gentle with me!
I have just competed a minor service on my 96 Excel 1.5 EFI 5spd and now the car is running rough. I've changed the engine oil and filter, changed air filter, cleaned and re-gapped the spark plugs.
I had an issue with the plug leads in that they were stuck kinda firm and I needed to use...
2 |
Aussie Boy |
264 |
30th April 2008 - 05:18 AM Last post by: Aussie Boy |
[B]hi
I have just bought a excel 1996 goes well for a week. start okay someitmes need a bit of pedal.
problem is sometimes it just stalls when i put the clutch down?
engine dies.
dont know why it only sometimes does it?
can anyone help?
2 |
sieger5 |
331 |
22nd April 2008 - 04:47 AM Last post by: sieger5 |
hey ppl does anyone know wich turbo manifold will fit a 1995 excel sprint i am having engine mount troubles with the one i have at the moment
0 |
XLZ-00M |
438 |
18th April 2008 - 07:31 AM Last post by: XLZ-00M |
hi
my 90 excel 5 speed was driving fine. went for a job interview got off freeway. stopped and excelerated and it popped out of 1st. stunned tried again and it did the same thing. drove 1/2 mile home in 2nd.. checking things found gearbox leaking oil replaced 2 qts..got better but still doing it. also clutch is acting a little mushy..
any suggestions.
thanks
5 |
yahoogirlz |
293 |
13th April 2008 - 07:59 PM Last post by: nvr2fst |
Ok not that good wiht cars...ok i was driving down the road and the Timeing belt came off the car and i want to know if i can get it fix with out costing out the But
and it been setting for about a year just did not have the time do get it fixed... Yesterday i wet out side and put it in N...
3 |
jrwalton2008 |
207 |
8th April 2008 - 12:41 AM Last post by: jrwalton2008 |
Hi
i have a 90 excel 5 speed drove it this morning no problems, got off the freeway and put in 1st and it made this thumping noise and it came out of gear.
well after checking a few things, tranny fluid very very low. well put in new gear oil (2 quarts) and drove it back and fourth a couple times and seem ok.
well when i drove it on the street it did it again. doesn't do it in...
0 |
yahoogirlz |
208 |
7th April 2008 - 08:27 PM Last post by: yahoogirlz |
OK so i love my excel she is like so hot!! anyways
i cant decide on pink fluffy seat covers orrrrrrrrr ones with NOS on them..... its so hard
i have a done a few mods already - love heart exhaust, chrome spinner hub caps and the seats are next.
Pls help
Tanya
4 |
sxc_excel |
323 |
6th April 2008 - 09:58 AM Last post by: nvr2fst |
Ok now that i figured out where the fuel pump is i have another problem. When the car was hit the radiator smashed the shifting linkage connected to the top of the transmission down. it is now jammed into some gear. Idk which. i tried pullin and hittin it back up with a hammer, but the linkage will not pull up. its a 5 speed incase no one has found out. the shifter moves easily forward and...
1 |
nvr2fst |
278 |
5th April 2008 - 10:47 AM Last post by: nvr2fst |
ok i just bought a 93 excel with 32000 miles on it and with a slipping trans
so i pull the tranny and open it up and rebuild it
but i need pics for the valve body i have one valve that i dont know how it goes together
i have exhausted all options: tranny shops, internet, dealership
thx for any help this is the only thing keeping me from putting it back...
0 |
joesnextoy |
255 |
2nd April 2008 - 08:12 PM Last post by: joesnextoy |
Hav a 89 Excel with no timing markings/settings.
Have no idea what to set it to & have tried advancing/retarding dizzy ith no luck.
Am thinking it might be a tooth out but tried that too.
YES there is spark as have checked all leads. TRIES to start but just won't tick over.
Does anyone have the right specs for timing as I have no book!
THANKYOU!
0 |
89hyundai |
300 |
28th March 2008 - 11:15 PM Last post by: 89hyundai |
I am needing a new ECU for my excel and I can't find any at the local junk yards and if I go to the store they wont almost 400bucks for one. I wanted to know is, is the ECU for my car interchangeable with any other car? its a 4sp and I was getting really awesome MPG and would love to get back on the road! Thanks in advance!
1 |
jeh1984 |
297 |
28th March 2008 - 07:27 PM Last post by: jeh1984 |
Hi guys my excel is pissing me off now. The leather boot around the manual shifter keeps slipping down and showing the rusty old selector. If anyone else has the manual tranny with the leather (ahem!) gear boot, has anyone been able to fix it? I tried araldite but it melted and my lever is all sticky. Can anyone keep it up? default/w00t.gif'...
2 |
wheel_of_steel |
227 |
27th March 2008 - 08:09 PM Last post by: wheel_of_steel |
I have a 1994 excel hb and it stals at acceleration i think the problem is the egr valve but i can't find it. I will apreciate any help and any picture would be great.
Thanks... default/liebe011.gif' 'liebe011.gif' />
1 |
ntoucet |
744 |
21st March 2008 - 03:45 PM Last post by: motorider |
I jus got a 1990 hyundai excel that someone hit a tree headon. nothin to major jus ruined the radiator and grill and light. well it cranks but will only start with starting fluid. I pulled the inspection cover behind the seat out and seen a plugin with three wires runnin into the top of the gas tank. is this the fuel pump or jus a sending unit? it has 6 volts comin from one wire but the others...
2 |
nvr2fst |
399 |
17th March 2008 - 07:42 PM Last post by: nvr2fst |
