Topic Title |
Replies |
Topic Starter |
Views |
Last Action |
Many people do not realise that Hyundai U.S.A. have provided a free online Workshop Manual for all the Hyundai models that are sold in America.
To use this click :-
Register (Internet Explorer required).....log-on, using the password they email to you, click `Service Information` & enter your car`s details & click the `Shop` tab.
It might be an idea to...
36 |
VALKYRIE YB70 |
22,653 |
25th May 2008 - 01:40 PM Last post by: Marcaccentgs |
In order that we can help you with relevant advice, please include AT LEAST your car`s model, year & engine size in your PROFILE!.
Thanks,
Nick.
1 |
VALKYRIE YB70 |
2,601 |
24th January 2005 - 08:29 PM Last post by: soullink |
| Forum Topics |
9159] default/57.gif' '57.gif' /> Just purchased a 2001 Accent GS coupe. Nice car. runs great. Would like to get some new rims/tires. Came with 13 inch stock tires and plastic covers. Would like source for later year "take offs" or a good source for some 15 inch decent...
1 |
ebluekeys |
24 |
Yesterday, 02:17 PM Last post by: _TuningMaster_ |
car - 2004 Accent auto.- 1.6l - 97K miles
After battling a few months to get my check engine light - fault code P0304 to go off I finally remedied the problem with 3 bottles/fill ups of STP Gas treatment. This was about 1500miles ago. I go to DMV Inspection station and sat for an hour then wait anther 20minutes for the test to end and was given the big fat rejection sticker, she failed...
12 |
273HYPO |
383 |
Yesterday, 01:08 PM Last post by: Chelle |
Fast approaching the 100K mark in the wife's '04 Accent (auto. trans 1.6l). So far the only real problem she's had is the cassette player is jammed...lololol. And check engine light for a misfire baffled me until I used 4 cans/fill ups of fuel inj. cleaner whch solved my problem.
I've done my own regular maintenance, oil changes every 3K, plugs, trans. flushed @ 65K, ...
8 |
273HYPO |
324 |
Yesterday, 01:04 PM Last post by: JBimmolate |
The car died and quit running! The OBD code indicated a "cam position senser." Replaced it, no luck!!! Through further investigation, by removing the top portion of the timing belt cover I dicovered that the timing belt was not turning even though it was in tact. By rotating it by hand I found approx. 20 teeth missing resulting in the crankshaft turning but not the cam. I...
1 |
D9Dave |
41 |
Yesterday, 01:01 PM Last post by: JBimmolate |
I have 2000 Accent, and I diagnosed faulty MAF sensor. I tried cleaning it and it didn't help. I have MAF sensor from old 1999 Accent that works, but it has 4 pin connector instead of 5 pin, and it doesn't have integrated IAT sensor.
How can I connect this old 4 pin MAF sensor and seperate IAT sensor to my 5 pin connector?
Does anyone have wiring diagrams of these two different...
Maf Sensor
how to replace 5 pin MAF with 4 pin MAF
0 |
zarez |
23 |
Yesterday, 06:33 AM Last post by: zarez |
i was wondering what reading i should expect as normal, or at least "properly functioning" from the O2 sensors on my 2000 Accent with a 1.5 litre. i have watched the numbers fluctuate when i hook it up to an OBD II, but wondered what range is good to indicate that they are functioning correctly. does anyone know what it would be, for both sensors, at idle and while driving?????...or at...
0 |
ejhirschberg |
14 |
Yesterday, 12:38 AM Last post by: ejhirschberg |
In late 2005 I started conducting my own reliability research. I'm reporting absolute stats like "times in the shop" that will make the differences between cars much clearer. Relative ratings obscure too much--how large is the difference between "better than average" and "worse than average"? I’ll also be updating results four times a year, so there will be...
14 |
mkaresh |
1,869 |
19th August 2008 - 01:21 PM Last post by: mkaresh |
My 02 Accent (GSI, 3-door, standard) has been giving me starting problems for a few months now. Usually it's fine but every once in a while it takes a while to start or won't start at all. It'll turn overbut won't ignite. The check engine light doesn't come on and the battery is fine.
I first took it onto the place where I get the oil changed - a fairly reputable...
23 |
ImOscar |
6,352 |
19th August 2008 - 11:44 AM Last post by: BobinIL |
I hope I'm not posting to much...
My 2000 Accent (GS 1.5 AT) gets around 24 mpg. I just got it, and I've tried to increase the mileage because I drive a long distance to work. The reviews on the car all say it gets 36MPG on the highway new, so I would expect it would get around 30 now.
I've put on a SRI w/ cone filter. Replaced the fuel filter, plugs and wires,...
36 Mpg?
Tips or tricks for increasing your mpg?
13 |
pearjam |
519 |
18th August 2008 - 08:25 AM Last post by: TommyR |
Hi,
New to the site and need a bit of help. I've just inherited a 2000 Hyundai accent 1.5 mvi and i am getting a couple of warning lights on the dash. I get teh ABS light and the Brake light on from startup. The brakes aren't making any strange noises and they seem to be pulling up ok.
Sadly i don't have the manual so can't check, does anyone know what the...
2 |
chew824 |
134 |
18th August 2008 - 07:46 AM Last post by: Squeak |
My car is a 2000 accent 2 dr, manual with the 1.5litre. when i bought the car at 60000 miles, it was getting 36mpg at best, then about 33. as of recently, ive seen 30, then 27mpg, now im down to 23mpg!!! this is like V6 mileage without the performance!! a year ago, at just over 80000 miles, the timing belt went, so i had that fixed and had to have a valve job done too. the car...
5 |
ejhirschberg |
72 |
18th August 2008 - 06:07 AM Last post by: gbajosh |
i'm modding my 04 accent and i want it different than any other accent on the road where i live , ive been modding it and still want to mod it alot more and i learned that the hyundai accent in most countries is called the "Verna" i debadged my accent and am thinking of ordering a verna badge , " see here for my car and what it looks like now , .
let me know...
0 |
AksentOner |
24 |
18th August 2008 - 12:10 AM Last post by: AksentOner |
So my 2000 Accent 1.5L Manual (SOHC) with 87000 miles has been having slight idling issue for the last couple weeks. It starts fine and idles fine until I drive it around a bit and let the engine warm up. After about 10 minutes the idle is not as smooth and I get a little bit of engine vibration (like it wants to start stalling) every couple seconds. It's not consistent on reproducing it,...
0 |
darkseamus |
21 |
17th August 2008 - 05:31 PM Last post by: darkseamus |
Hello All,
Recently i got Engine check light on the car. After scanning with my colleague's code reader i found P0130 OBD on my engine checkup.
P0130 O2 Sensor Circuit Malfunction (Bank 1 Sensor 1)
From previous post i found that its the sensor thats closest to the engine and its attached with the exaust manifold. I am in uk and the car i have is 1350 CC...
3 |
mihir3 |
190 |
17th August 2008 - 02:20 PM Last post by: afbtstix |
The check engine light is always on. I changed so many parts including the gas cap, sparking plugs, air filter etc. I disconnected the battery too but the light goes on again. Any advices?
3 |
Discman |
132 |
17th August 2008 - 02:12 PM Last post by: afbtstix |
I own a 2002 Accent with 82,000 miles on the body and 102,000 miles on the motor. My timing belt went when I was driving and required an engine swap. Since that time I've been getting the error codes P0030, P0031, and P0135. Does this deal with the O2 sensor that's not located on the manifold and if so, what can I do to fix the problem? Will replacing the O2 sensor and the fuse work or...
0 |
chickw/astick |
20 |
16th August 2008 - 11:37 AM Last post by: chickw/astick |
For those of you who neglect your "routine" maintenance of changing your timing belt every 100 000 km. I have potentially good news, mine failed and there was no damage to the valves or anything... other than the belt.
My timing belt failed while I was driving, and i was worried that it may have bent a valve or something, but as it made no noise when it failed I figured I was...
4 |
srawrats |
230 |
16th August 2008 - 11:20 AM Last post by: D9Dave |
(I already replied in the thread titled 2002 accent won't start, but I'm starting a new thread in case my situation is different, or anyone else has any suggestions...Thanks!)
Hey All. I have a 2001 Accent, 54K miles (Sig needs updating) and automatic trans. Always runs beautifully.
In January, I was travelling, when I stopped somewhere and turned off the car....
31 |
cstephen |
1,703 |
15th August 2008 - 10:48 AM Last post by: redJack |
Hello Folks!
Wonderful place here with lots of information... I searched but didn't find anything similar...
I have an 03 Accent GL 1.6 that I replace the Crankshaft Position Sensor with an aftermarket one when the car died one night on the way home and would not start.
Now I get a very strange starting problem, the starter sound like it binds up after the...
8 |
Troll_Dragon |
246 |
15th August 2008 - 09:49 AM Last post by: TommyR |
What can cause this? Ive done plugs, wires, o2 sensors, MAF, and checked the TPS.
2 |
Lockedup |
54 |
15th August 2008 - 06:06 AM Last post by: 273HYPO |
Hey everyone!
Looks like a lot of knowledge floating around here so I thought I'd arm myself with some of it before I bite the bullet and take this thing to a dealership (if necessary). Very recently (within a week) the shift lock has started to act up - I can't shift out of park to drive even with the brake pedal depressed. However, it's not constant; in that sometimes...
1 |
darwinain |
54 |
14th August 2008 - 08:20 PM Last post by: rancal |
Having my first technical issue with my 3,5 years old Hyundai Accent.
During past years the engine coolant temperature gauge was - after warming up - always pointing to the middle of the scale (inbetween the two small dots). This was not depending on vehicle speed or outside temperature.
Since a few weeks I experience following problem:
The gauge is showing higher...
5 |
Atti_5 |
123 |
14th August 2008 - 08:16 PM Last post by: rancal |
Just wondering if anyone has ever had this problem which happened to me this week. I left the house to go to work. I lost overdrive for the day. The engine light came on and there was no overdrive. Car was running fine before that. The next day I got overdrive back but the engine light was still on. Car ran fine. When I left work that evening the engine light was off and seems to me the car ran...
2 |
Twok |
113 |
14th August 2008 - 08:02 PM Last post by: rancal |
Hey,
I just joined/Bought a Hyundai Accent 2000. Im looking for a Good repair/shop Manual for it.
The Online Manual Stickied above would be perfect, but to print it off requires going into each category/subcategory and printing each section piece by piece, which would take a looong time.
Just wondering If anyone has saved the entire Manual to PDF or Word Format so...
0 |
Tiqil |
61 |
14th August 2008 - 02:18 PM Last post by: Tiqil |
I own a 2001 hyundai accent 1.5L 2 door hatch back 5 speed manual, and ive done some upgrades like a much larger exhaust, cool air intake, and rims and tires. now i have been trying to find if anyone knows of some where i could get a disc brake convertion kit for the rear drum set up. and also if any one Knew wut the largest amount psi turbo i could put on my vehicle with the minimal internal...
3 |
thedonkey69 |
86 |
14th August 2008 - 11:19 AM Last post by: Lucid484 |
hi guys,
looking for some advice. my girlfriend has a 2001 hyundai accent and to me, it revs pretty high. its at 4k rpms when its on the highway at 65mph. im not sure if this is normal for an accent or not. if not normal, do you guys know what some likely causes might be?
some background: it only has 45k miles on it and its an automatic. had a tranny flush about six months...
10 |
limerence |
197 |
13th August 2008 - 11:18 AM Last post by: bowsercake |
Hey, im new to this forum and new to hyundai's. I bought a 2000 accent it has the 1.5 SOHC motor and its a 5 speed, when i bought it it had a hard time starting so i traced that back to the MAF sensor, and it solved it. But latley it has a really bad stutter when you hit the gas it almost stalls out, and when you take off from lights you have to rev it up first before you try to accelerate...
2 |
Lockedup |
95 |
12th August 2008 - 05:59 PM Last post by: Lockedup |
I have a 2001 hyundai accent 120000 miles. I have not had any problems with the car. I had to replace the fuel cap once and have used synthetic oil for over 100000 of those miles. I just had the check engine light come on and autozone pulled up the 1128 code. My car spark knocks all the time even with mid grade (which I should not have to use). The code says it is running lean and could be part of...
2 |
tluney |
83 |
11th August 2008 - 01:13 PM Last post by: JBimmolate |
Yesterday i hooked up a code reader and it showed codes 1128(Mass air sensor) and 0121 (Throttle position sensor). I replaced the TPS and the check engine light came on again, so i checked the code again and the MAS dissapeared and the TPS came back on, i unhooked it and hooked it back up, also when i clear the check engine light the car runs like crap for a good 5 miles of driving then the check...
4 |
Tydock |
195 |
11th August 2008 - 01:11 PM Last post by: tluney |
hello, first my english is a litle bad, i am french canadien.
I turboed my accent 2006(lc2)
My stock list:
1.6L
turbo kkk03 set at 7psi
bov
intercooler
home made simple AFC(when boost occur computer see O2 sensor very lean an enrich mixture at aprox 12-13:1..it's work good)
home made return line
FMU 6:1 and FPR
i have probleme...
3 |
alexlab79 |
112 |
11th August 2008 - 08:50 AM Last post by: alexlab79 |
Does anyone know if any sport compact company or even independant builder, makes performance mods for the 1.5liter sohc? I've exhausted what little options I thought would work,in my current search for more pep outta the accent 1.5l.
i.e.: HEADERS, INTAKES (NOT SHORT RAM), FUEL DELIVERY, EXHAUST, AFTERMARKET OR IMPORTED ENGINES AND TRANSMISSIONS.
I really appriciate any...
4 |
kyles200sx |
262 |
10th August 2008 - 03:05 AM Last post by: thedonkey69 |
Sort of new to the world of motoring and the world of hyundai!
Have a 2001 Hyundai Accent and although its sleek looking as it is I would like to jazz it up slightly.
Looking for:
New mesh grille similar to the one someone else posted here.
New spots to replace the bland holes that are there
Alloys, I have 13" wheels tat came with it. What size...
2 |
roofie |
168 |
9th August 2008 - 11:20 AM Last post by: _TuningMaster_ |
Hi folks,
I'm going to be replacing my timing belt on Friday.
I need directions on how to do this - I know that the directions are somewhere in the forums here, but I can't find them - when I think I've found them, they don't apply or the info isn't there.
So could someone please post a step by step, or give me the link that goes straight to the...
3 |
pearjam |
160 |
7th August 2008 - 08:40 PM Last post by: RetsaM |
Need help on parts for my accent!!!! I just recently purchased my accent and was looking to get parts for it ,but i'm having trouble due to the fact that there are'nt that many website for parts that I know of. I was looking at purchasing a turbo kit for it but cant find one anyways if anyone knows some great sites to look on please let me know. Thanx
2 |
Westly |
124 |
5th August 2008 - 03:10 PM Last post by: bowsercake |
Hi, I own Hyundai Accent 2001 1.5L SOHC.
I have the P1123 code.
I have replaced the Oxygen sensor, and the Air filter.
I've Checked the Air Purge control valve, and the mass air flow sensor, all is working perfactly.
But still, the P1123 code is coming back.
what should i do next?
1 |
froggy85 |
76 |
5th August 2008 - 11:50 AM Last post by: RetsaM |
Hello,
I have just finished replacing the timing belt on my sister 2002 accent.
4427]
The worst was the Water Pump Pulley.
In the HMA Service web page they say "Remove Water Pump Pully"
Yeah right!
You have to support the motor with a jack, remove left Motor Mount,
Jack the motor enough to get access to those 4 bolts holding the...
7 |
RetsaM |
821 |
5th August 2008 - 11:45 AM Last post by: RetsaM |
We recently purchased a new 2008 Accent GS invoice + 1500 rebate it was a really good deal. Have been really happy with it.
Anyway we saw a used 2003 on the same dealer lot. Initially they wanted 7,000 we talked them down to 6084 out the door- but I felt 4500-5k was probably a more realistic price for the car. It was the hatchback with the only option being A/c and automatic...
3 |
afacade |
117 |
5th August 2008 - 08:33 AM Last post by: Lucid484 |
I started looking at my grill and took off the plastic part and I would like to know how to put a mesh grill in. I already ordered the mesh but there must be a way to put it in so it looks pleasing. If anyone has instructions or pictures on how to do this I would appreciate it.
8 |
ShockWave |
819 |
3rd August 2008 - 12:43 PM Last post by: srawrats |
Hello everyone! This is my first time visiting the forum. I have to say I didn't know so many people tuned Accents! I have a Black 2005 Accent GT. It is the 1.6L with an auto tranny,fog lights, stock alloy rims, and stock wing for those high speed runs! LOL anyway. I really wish it was a standard transmision, but hey, I have to work with what I have. Plus my Accent is in great...
7 |
JaccentGT |
144 |
3rd August 2008 - 04:01 AM Last post by: JaccentGT |
The car was given to me from a friend, it wasn't well maintained, has 170,000 miles and some problems.
The girl who owned it lived on a street with a dip at the end and it would regularly catch somewhere under the car and make a horrible noise. The car leaks oil in the front when parked (in several different places). I believe it may be that the oil pan is badly dented or even...
1 |
CheekyMonkey723 |
137 |
2nd August 2008 - 02:26 AM Last post by: bowsercake |
My 2001 Hyundai Accent was in the shop for about 2 months and so far I forked over a total of $1100 to put in a used engine. My mechanic would tell me it would be done on a certain day and when that day came he would tell me that its not ready because he made a mistake and now it's leaking transmission fluid. He told me that he had to replace some kind of plate. Finally he said it was...
2 |
DOverly79 |
114 |
1st August 2008 - 08:12 PM Last post by: AksentOner |
Just had an engine replaced and now I am leaking tranny fluid. My mechanic said that when my engine locked up it must have put a crack in the torque converter causing it to leak. I know that it is not a problem with the tranny because when I put fluid in it runs good. Is this possible? I don't know if it would be some kind of mistake my mechanic made when replacing the engine. It just does...
2 |
DOverly79 |
95 |
1st August 2008 - 04:18 PM Last post by: DOverly79 |
Hello again everyone,
Ok, so I have over 124,000mi on my 2000 Accent, so I want to change the timing belt.
Has anyone here done that, and can explain how to do it?
2 |
pearjam |
246 |
1st August 2008 - 03:49 PM Last post by: srawrats |
I decided to examine the condition of the rear brake shoes on my 2002 Accent. I undid the tension on the handbrake and got the drum off. I wanted to show my son how the handbrake affected the motion of the shoes, so I had him pull up, and then lower the handbrake with the drum off. WHAT A MISTAKE. Now the shoes are fully "out" and don't want to return. The piston pushes back in...
5 |
smichelsen |
139 |
31st July 2008 - 01:01 PM Last post by: theiceage05 |
I just bought some white faced guages for my 2000 accent, i have a couple of ?'s.
Which model cars did these come in, and are lit by LED's there are a couple of very faint black spots behind the guages is this normal? Thanks.
0 |
ramichael |
99 |
30th July 2008 - 06:33 PM Last post by: ramichael |
For sale are thermal phenolic intake manifold spacers for the 00-05 Hyundai Accent 1.6 dohc. These are just like the one hondata sells but are made from a different phenolic material. Drop the temperature of your intake manifold dramatically and free up horsepower from the colder intake charge these spacers will give you. You can e-mail me at boostedbeast@verizon.net for order details or pm me.
16 |
JRM |
463 |
29th July 2008 - 03:22 PM Last post by: Lucid484 |
I just got my 2001 Accent back about 7 hours ago from the shop. I got an engine replaced for the second time in a year. I did a little test driving tonight and as I was pulling out of my street I accelerated but there was a couple second delay and the car took off. I had no tranny problems before I gave it to my mechanic. It did the same thing about 4 or 5 times on my test drive. My mechanic said...
0 |
DOverly79 |
146 |
28th July 2008 - 11:14 PM Last post by: DOverly79 |
I have a 2000 hyundai accent. It has new battery. When I turn the key it makes a loud ticking noise. The Headlight are bright so I know its not the battery. Could this possibly be the starter? How hard is it to change the starter?
0 |
Trinimd |
108 |
26th July 2008 - 09:27 PM Last post by: Trinimd |
