could anyone help me with a small problem i have.
my reverse lights stay on constantly and i was told by my father in law that it is my reverse light switch. so i contacted the main dealer who has managed to get me on that i have to pick up tomorrow.
the question is where is the switch located and could a novice like me change it.and what am i looking for
3 |
cossie123 |
280 |
27th March 2008 - 05:18 PM Last post by: Hyundaiownersclub |
When I turn the front lights on, there is a rattling/ticking from the passenger side front headlights (UK model). This noise occurs even when the engine is off, as long as the ignition light is on and the lights switched on, the noise appears. Turn the lights off, the noise goes!! I have checked the connections and all seems tight - the lights work fine - has anyone else has this...
1 |
quoman1234 |
351 |
27th March 2008 - 06:56 AM Last post by: malteser66 |
Hi everyone, i have just got myself an atoz to use as a second car and it seems to have a dodgy fuel gauge has anyone got any idea how much is left in the tank once the low fuel light comes on ? Also how efficient is the air con mine seems to be no better than when the fan is on cold .
4 |
akita1 |
409 |
13th March 2008 - 05:23 PM Last post by: Hyundaiownersclub |
Hi there. Hope someone can help. Have a 2000 Amica SI with an intermittent fault. Car will be fine for weeks and then overnight the battery will completely discharge as if there is a short. Nothing left on, not lights , interior lights ,ignition, radio. Everything checked as off. No warning lights when engine running like alternator fault...nothing. Has anyone had this same problem. Only thing I...
1 |
classicol |
350 |
26th February 2008 - 04:15 PM Last post by: joecamel |
default/' '' /> hi i have a problem with my elec windows they will not work(dead) as anybody any help with this. default/banana.gif' 'banana.gif' />
2 |
fozzy |
286 |
20th February 2008 - 03:03 PM Last post by: fozzy |
I just bought a Hyundai Atoz for almost nothing, one of the problems being that it is missing 5th gear.
First I thought it would be linkage related, but it seems to select 5th fine, there is just nothing there - it revs freely.
I'm thinking that 5th gear is probably stripped, so I might need to pull it out + replace, or at least give it a clean up and use it as a 4-speed...
1 |
Rack |
486 |
13th February 2008 - 04:11 PM Last post by: Hyundaiownersclub |
My Atos is consuming 8Lt/100Km is this normal??? default/unsure.gif' 'unsure.gif' />
I recognise i live in a mountain, with up and down the hills streets, but still i wanted to know your cars consumption levels.
Usually, every time i go to the gas station, I register the Km i made...
0 |
gunthy |
349 |
13th February 2008 - 03:31 AM Last post by: gunthy |
Hello im new to this forum =)
I would like to ask if there is any possible way to get the hands on the service manual and workshop manual of the Hyundai atos because ive been looking all over internet and i cant seem to find them, not even buy them
thnx in advanced
Arcadien
or if somebody wants to mail me arcadien@gmail.com
2 |
arcadien |
2,391 |
13th February 2008 - 03:05 AM Last post by: gunthy |
hi all,
just a bit help required, i have an amica 2002, which i am trying to fit a stereo, with alot of difficulties.. i have noticed that the power cable has no power coming from it... i have checked the fuse box. and that seems to be normal. it did not have a stereo fitted when i brought it.. any help would be appreciated
thanx
0 |
aftabz |
223 |
10th February 2008 - 06:44 AM Last post by: aftabz |
my atoz wont start it turns over but wont fire it has fuel it was involved in a crash is there a fuel cut off switch anywhere
7 |
mistybing |
457 |
5th February 2008 - 09:22 PM Last post by: mistybing |
default/whistling.gif' 'whistling.gif' /> hey my atoz was involved in an accident my partner rebuilt it and it was fine then all of a sudden it wouldnt start it turns over and sounds like it going to fire but doesnt help please is there a fuel cut off switch anywhere or do you have any...
0 |
mistybing |
240 |
4th February 2008 - 04:22 PM Last post by: mistybing |
After how much kilometers the timing-belt of Santro (Atos) should be checked/changed?
I am asking this because I have heard that if it brakes on the move then it causes serious damages to the engine, therefore it should be inspected and changed well in time.
7 |
Junaid_Hassan |
1,220 |
4th February 2008 - 04:21 PM Last post by: Hyundaiownersclub |
default/w00t.gif' 'w00t.gif' />
I have an amica done 50000 miles 2001 GSI, I have a dreadful noise when driving, checked gearbox oil thats ok, it jumps out of 2nd gear at low speeds also.
The noise increases as I increase speed, the car seems to lack power also. the noise is...
1 |
lem4crm |
534 |
4th February 2008 - 04:11 PM Last post by: Hyundaiownersclub |
Hi Everyone!
Just bought a new CD player to (finally) replace the old rad/cass in my 2000 Amica. The CD unit drives 4 speakers. My AMica has no rear speakers but has the vacant 5" bays at the back (where the parcel shelf is held up) to take a pair of speakers. I removed the plastic bays and there are holes in the chassis to connect the speakers to the cables but I dont see any...
2 |
phoenixx9000 |
296 |
4th February 2008 - 02:35 AM Last post by: joko |
Hi,
We've got a 1998 Atoz which has an electrical fault, the headlight reminder stays on constantly even when lights are off, this is beginning to get annoying has any one got any suggestions to stop it.
John
3 |
thelittlebluebox |
488 |
31st January 2008 - 08:20 AM Last post by: lintdrummer |
Hi all,
I bought my mum a 200 X plate Amica 1l GSi Auto. It was fine for a month or so, then it started stalling when you pulled up and were waiting in traffic, It would start up again as soon as you turned the key, so we took it back to the dealer. The dealer put it on a test and it showed no fault codes. He had a mechanic clean the injectors. This solved the prob for a couple of days but...
3 |
maddips |
371 |
30th January 2008 - 06:38 PM Last post by: Hyundaiownersclub |
Good day all,
I need to install an RPM counter/Tach meter in my 2006 Atos.
I have done so on a car with a coil before, no problems, but can not find somewhere in the Atos to pick up the pulse from.
Any suggestions? I need the Tach to monitor RPMs to prove a problem on the motor...
The Tach I have needs a pulse, anybody know how to get an inducted...
0 |
renegade |
312 |
21st January 2008 - 02:52 PM Last post by: renegade |
Good day all,
I have a 2006 Atos Prime GLS manual that has run flawlessly for about 14000Kms. At this point it started idling eradic. What I observed is that it will idle fine, and suddenly the revs will drop for a fraction of a second and stabilize again.
At just under 15000Kms the same behaviour became noticeable when driving. Doing any speed from about 60km/h to 120km/h...
0 |
renegade |
360 |
21st January 2008 - 02:48 PM Last post by: renegade |
Hai everyone
I own a hyundai atos automatic, recently the gearbox giving problem, it cant REVERSE default/blink.gif' 'blink.gif' /> anybody have a similar problem before please reply to this email or advise me if i can repair it my self. Your comment and reply is high...
4 |
yazidtek |
5,470 |
18th January 2008 - 05:56 AM Last post by: charlene150 |
