| mserino |
Oct 21 2007, 12:10 PM
Drives: 1992 hyundai scoupe Status: OFFLINE
i have a 1992 scoupe 1.5L this car turns over fine! it just refuses to start! i know there is spark and gas. any takers on this????
| mserino |
Oct 21 2007, 05:43 PM
anyone out there know anything on this problem. is there even a crankshaft sensor on these vehicles???.
| TPA |
Oct 21 2007, 06:07 PM
Drives: Scoupe 1.5 GT 25 special 1993 Status: OFFLINE
QUOTE(mserino @ Oct 21 2007, 11:43 PM) anyone out there know anything on this problem. is there even a crankshaft sensor on these vehicles???. yes it has. If i knew what the issue whas exactly i would say it. But i dont know it
| mserino |
Oct 21 2007, 07:29 PM
where is it located i cant seem to find it? i also heard that these cars have an optical sensor built in the distributor and it acts like a hall effect sensor. except the hall effect sensor kills spark and the optical sensor controls fuel injection.
| evotistical |
Oct 21 2007, 10:37 PM
Drives: 1991 Hyundai Scoupe, 2 Suzuki Renos Status: OFFLINE
You have a Mitsubishi engine being a 92, 90% of the time it is a bad ecu. take your ecu out, open it up, and smell it. if it smells of rotten fish then your capacitors are bad, (replace or repair). your ecu is a squarish gold box either under the drivers side or passenger side kick panel(under the dash) that is about 20% larger than a cd-case. another prevalent problem is bad timing belt but this usually fails while driving. to check the timing belt remove the cover (its like 4 screws at the top). also you can check the spark by removing the wire that goes from the coil to the distributer and touching it against a metal part of your engine to see if a spark jumps while turning over the engine. then plug it back in and try removing one of your spark plug wires(carefully) and do the same. don't worry about the hall effect mumbo-jumbo until you've tried at least these steps. as an owner of over 10 4g15's in past years, i know what ails them usually.
This post has been edited by evotistical: Oct 21 2007, 10:42 PM
| mserino |
Oct 26 2007, 06:55 PM
i thought that if the crank sensor is bad then there would be no spark????....
| Schwitzer Turbo |
Dec 2 2007, 06:42 PM
Drives: Scoupe gt 95 Status: OFFLINE
QUOTE(WhiteScoupe @ Dec 2 2007, 04:40 PM) Hi all does the 92 scoupes (mark 1) have a crank position sensor? If so where is it located? Currently my scoupe sometimes works fine and other times it runs very rich and a lot of black smoke comes out of the exhaust. Has any one had this situation before? Your temp sensors is fucked, when the ecu gets told it is cold ecu sends more fuel almost like a CHoke. other than that your maf is getting the wrong readings.
| thermos |
Jul 3 2008, 05:44 AM
Drives: 2002 Hyundai Scoupe Status: OFFLINE
My Scoupe MkII is having starting problems in that when the ignition is turned to ON, (intermittantly) the Check Engine light does not glow and the car wont start. I can hear the starter motor when the ignition is turned to START, but it wont start.
I am thinking:
Immobiliser Main ECU relay Fuel Pump relay Starter Relay Faulty ECU?
Any ideas would be great! Thermos
Track this topic
Subscribe to this forum
Download / Print this Topic
Link To Us
Similar Threads
Similar Threads
21st August 2008 - 01:39 PM |
