 Hyundai-Forums.com > Hyundai Models > Tucson Forum
> Compatible Homelink Rear View Mirrors, Want Homelink mirror on Tucson Limited
tennisailor
post Dec 13 2007, 05:15 PM
Drives: 2007 Sonata 3.3
I have a 2007 Tucson Limited with auto dim/ compass mirror. The homelink mirror is not offered in any Tucson models. I have a 2007 Sonata Limited with Homelink mirror. I was wondering if I bought a mirror for my Sonata, would it work in the Tucson, or is there an aftermarket that will hook up in Tucson...help
Thank
Itsatusconmatey
post Dec 18 2007, 02:46 PM
Expert
Whats a Homelink Mirror? Never heard of it in the UK Please advise
Itza
byronguidry3732
post Dec 18 2007, 05:50 PM
Group Icon
Group: Super Mod
Drives: 2003 Tiburon GT 2.7, 2004 Santa FE FWD 2.7, 2001 Sonata 2.4, 1984 Pontiac Fiero SE
Dear itsat,
A Homelink rear-view mirror can be coded with your remote garage door opener code and then replaces the original remote. The Homelink mirror is permanently mounted in the vehicle, so losing that little garage remote is no longer a problem.
" The sophisticated HomeLink® integrated transceiver, incorporated into the inside rearview mirror of select Hyundai models, can operate compatible garage doors, gates, and home lighting and security systems. "
Tennis,
You are absolutely right that the 2007 Tucson Limited does not have the Homelink mirror as standard or an option.
I was trying to access the wiring schematics for the 2007 Sonata Limited rear view mirror versus the 2007 Tucson Limited. The Sonata does have a seperate Homelink 12 volt line in the connector and the ground is shared. Pins 6, 8, 9, and 10 are active.
The Tucson has an identical connector for the electrochromic mirror, but only pins 1, 6, and 10 are active. Drum roll...pin 6 is the 12 volt power in for both the Sonata and the Tucson applications.
You can make this work! You will have to reconfigure the wiring to the pins match the Sonata pattern for pins 6, 8, 9, 10, and run 1 additional power lead from pin 8 to the fuse box but you can make this work.
How expensive is the Homelink mirror from the dealer????
Byron
RickB
post Jul 7 2008, 07:07 AM
Drives: 2009 Sonata
Byron - as posted elsewhere, I have purchased a used Sonata 2005 electrochromic mirror which is OEM. It is destined for a 2001 Sonata. Unfortunately it did not come with a pigtail and I doubt if the 2001 is prewired for an electrochromic mirror. Do you have a drawing of the connector showing pin numbers and function? That would be really helpful if you do. Also - any idea if the base 2009 would come pre-wired for electrochromic mirror if it was not sold with one? Thanks. RickB
No New Posts Rear Drum Noise (brake Rubbing)
Drum Brakes
7 ACCENTUATEthe+ 115 1st January 2009 - 04:52 PM
Last post by: moonz
No New Posts Rear Sub / Speaker Shelf Vibration
Old problem...still no fix???
8 8NT2PRD 720 30th December 2008 - 10:05 AM
Last post by: allmet33
No New Posts Rear Parking Sensor
Rear parking sensor
1 andymort 98 19th December 2008 - 06:22 AM
Last post by: mojakarykatura
No New Posts Topic has attachmentsRear Wing & Matching Kit
Rear wing & matching kit
8 tsaaaron 1,053 14th December 2008 - 09:27 AM
Last post by: williamz
No New Posts Rear Seat Entry Uk Coupe 02
broken walk in device
3 alexphil20 27 10th December 2008 - 10:48 AM
Last post by: byronguidry3732
6th January 2009 - 03:03 AM
