QUOTE(Philip Varney @ Jul 10 2008, 03:44 PM)
I have had my top of range CRTD CDX since new and still find it way above other 4 x 4 SUDs. Tried a new I 10 the other day not for me too small.
Cruise control is what I like about it even though its Manual and the 5 year warantee is excactly that with two new keys new wiper arms and recently a new prop shaft as the other was noisey with no trouble at all makes it a great buy. Only niggle is fual consuption at 21.5 US after 45000 miles and 16 US when hitched to my Caravan.
With disel at £1,30 2 dollars a litre it really hurts.
Otherwise no better buy about.
Philip Davies
Hi Phil and a big :00000732: to the forums
I am now opn my 2nd Tucson my first a 2.0crtd cdi I bought in 2004 when they first came out and together with many other original owners we kept on at Hyundai UK about the crappy consumption and the fact that the fuel guage sender was calibrated to US gallons- well after a while Hyundai came up with a new speedo cluster and also a ecm upgrade.
It sounds to me as if the upgrade may not have been done with your Tucson but if its registered before about june 2005 then this may be the case.
If you do a search up the top right of the page under fuel consumption diesel you will be able to get some of the answers you need.
My 2004 eventually got up to 34mpg solo and 26-28 towing my caravan.
I eventually traded it in in Jan 2007 for a Tucson 2.0 CRTD CDI Limited with 6 speed gearbox and what a difference the Evo engine makes and the BHP is up from 113 to 138 and this helps with the towing.
I also use a powerbox as do many of my tucson owning collegues and details of that can also be obtained - pm me for a copy of the report.
You can also contact me through www.tucsondrivers dot com where I moderate and also at the Hyundai owners club of gb at www.hyundaiownersclub.co.uk
Now have a search around my friend as this was the forum that has all the original information as up to 50 of us posted quite a bit of information.
Where in the UK are you? it helps if we know as someone may live near who can get you up to date with a personal visit maybe.
Cheers for now
Itza :460: :460: :460:
