 Hyundai-Forums.com > Hyundai Models > Azera Forum
> Warbling Noise, Front end
ptntms
post Jul 5 2008, 11:50 AM
Drives: 2006 azera limited
I have a2007 Azera with 21000 miles that after about five miles developes a warbling noise in the front. Had tires rotated and 4 wheel alignment but no change.
Different road surfaces add noise but the warble is always there. Anyone else had this problem? Any resolution? Thanks
david-paul-1
post Jul 5 2008, 04:02 PM
Expert
Drives: 2008 Chrysler Sebring Convertible Pearl Marathon Blue, 2007 Santa Fe Limited Pearl White
QUOTE(ptntms @ Jul 5 2008, 09:50 AM)
[right][snapback]174293[/snapback][/right]
Did they check your tires for cupping?
David<><
snaglepus
post Jul 6 2008, 09:25 AM
Location: Murrieta, in Riverside County, Southern Kaullifornieia, USA
Drives: 2007 Azera SE Limited, build date 12-12-2006, and 'Old Faithful,' our Kona Ford Focus
If that 'noise' occurs only after the car has been driven "about five miles" how can it be cupped tires?
If it were cupped tires, wouldn't the 'noise' be there at all times even when the tires are cold? :whistling:
When the alighment was done, wouldn't the tech have pointed out any badly cupped tires?
Could all four tires be cupped that badly, assuming that
they have been properly rotated in a timely manner?
How long has this been going on and is it getting progressively worse?
Maybe a bad wheel bearing that gets noisey after warming up?
As you can plainly see, I'm only on a fishing expedition! :grin:
Good luck. Please let us know when you discover what the problem is.
:amen:
( :innocent: )
This post has been edited by snaglepus: Jul 6 2008, 09:32 AM
andyman32
post Jul 6 2008, 12:04 PM
Expert
Status: Online
Drives: 07 Azera Ultimate #1, 07 Azera Ultimate #2, 96 Vanden Plas, 97 XJR
QUOTE(ptntms @ Jul 5 2008, 12:50 PM)
"Warbling" is a little obscure - hard to describe noises in words. Is it a high-pitch squeaking sound, like a metallic 'chirp', or an oscillation in road noise coming out of the tires? If it's the former, can you tell if it's coming out of the wheels on either side, or out of the engine bay? If you roll down the windows and drive past a reflective surface like a wall or barrier close to the street, does the sound reflect back to you? Or are you just hearing it inside the car?
It wouldn't be bad wheel bearings. Bad wheel bearings make a kind of 'turbine' sound. If it's a squeak, it could be a bad pulley bearing on the accessory belt in the engine, a warped rotor that's squeaking against the pad, or touching the stone guard on the back of the steering knuckle. May also be that CV joints need to be lubricated.
ptntms
post Jul 6 2008, 02:20 PM
I thought something would change when I had the tires rotated. I thought it might be cupped tires but I cannot feel anything when I run my hand around the tires,
The noise, after it starts get louder as I slow down to a stop. The harder I press on the brakes the louder it gets. The brakes were checked and there is no pulsing when stopping. When I go over a rise in the road the noise is less. When I sway the car back and forth I cannot tell any difference. Down shifting does not change the noise nor does shifting to neutral.
Back to the dealer.
david-paul-1
post Jul 7 2008, 03:03 AM
Expert
QUOTE(ptntms @ Jul 6 2008, 12:20 PM)
Back to the dealer.
[right][snapback]174455[/snapback][/right]
It is very possible for a tire that is cupping to get louder as you brake hard.
The rogue tire is being pressed against the pavement harder than usual and any unusual tread wear will get louder under this condition.
Keep in mind that just because some tech balanced your tires does not mean he inspected each one carefully.
Just an idea. Could be many other things also. Best to check the simplest things first before completely rebuilding the entire car. :)
We will be very interested in hearing what you find out when the problem is solved. Keep us posted.
David <><
joezera
post Jul 7 2008, 07:07 AM
Drives: '07Azera Ltd, Premium, 3.8L V6; Dodge Ram 5.9L I-6
ptntms;
QUOTE
I have had tires that looked completely normal and yet had the sound you describe. It turned out to be tires with the tread separating from the body of the tire. It can usually be seen only when the tire is in motion. You have to get someone to watch the tires closely as you drive by slowly. This is one of the hardest types of problems with a tire to diagnose.
Other member's suggestions are good areas to check on too. Good luck! :)
Joe
snaglepus
post Jul 7 2008, 08:46 AM
QUOTE(joezera @ Jul 7 2008, 05:07 AM)
ptntms;
Joe
[right][snapback]174585[/snapback][/right]
Hunter GSP9700 :amen:
If the tech using this machine knows what he is doing, and if the noise is being produced
by a tire that is having tread seperation, the "Road-Force" test will 'load' the
tire much the same as if it were on the road, and both of you should be
able to both see the problem and also hear the noise.
:thumbsup:
This post has been edited by snaglepus: Jul 9 2008, 07:46 AM
No New Posts Noise Right After Chaning My Cabin Filter
8 bryanhas06sonata 130 1st December 2008 - 12:55 PM
No new Noise From Front Window
Hear a whistling noise at high speed
29 Sparks 2,940 3rd July 2008 - 06:12 AM
Last post by: pvdossel
No New Posts Noise From Rear Of 2005 Elantra
HElppppppp!!!!!
1 JAKE9364 122 13th May 2008 - 10:55 AM
Last post by: marek46
No New Posts Noise From Steering
16 whiterabbit 562 2nd May 2008 - 03:04 PM
Last post by: whiterabbit
No New Posts Noise (low Whistle, Or Like A How) At 125 Mph
10 hmr1979 327 15th April 2008 - 06:12 PM
Last post by: dcjwlee
6th January 2009 - 06:21 AM
