 Hyundai-Forums.com > Hyundai Models > Elantra & Lantra Forum > 2G (1996-2000) Elantra & Lantra
> Once In A While Lantra Won't Start, Lantra occasionally doesn't start
EdGasket
post Jul 6 2008, 10:02 AM
Drives: Hyundai Lantra GSI 1.6 2000
I have a 99 Lantra 1.6 which very occassionally won't start from cold; just goes on cranking. The only solution is to leave it for about half an hour or even until the next day and try again. I would say its only 1 in a hundred times but can be very inconvenient if its an important journey ! I met someone else recently who has the exact same problem on his Lantr 1.6 so it must be some common ailment.
I also notice that often when starting, the engine does not catch until the point where I release the key from the starting position and it then starts from its own momentum; like its not getting enough electricity to fire with the engine turning over under the starter motor. Compare this with my sister's Rover metro which fires up at the slightest touch of the starter.
I have run an extra earth cable from the battery straight to the cylinder head which seemed to help but I have still had the problem since then.
Once started it runs fine and has not been a problem when starting from hot.
Is there any particular relay or connections that I should clean to help get more juice to the coil or any other reason for this problem?
marek46
post Jul 6 2008, 01:47 PM
Drives: Lantra 1.8 1996, Getz 1.3 2002
Hi, Ed!
Can you hear the fuel pump buzzing just before starting?
cheers,
Mark
EdGasket
post Jul 6 2008, 03:30 PM
Yes, I hear the fuel pump prime for a few seconds when the key is turned to the second position. Also after a lot of cranking it smells of petrol i.e. flooded; just doesn't seem to fire up sometimes. Its had new plugs and leads recently too. Its like there is just not enough power in the ignition to make a spark under the load of the starter motor cranking.
EdGasket
post Jul 26 2008, 03:51 PM
I think I found the problem. The new HT leads have double the resistance of the old ones e.g. the new longest HT lead is 7K ohms whereas the old one was 3.2K ohms. I also noticed that the new spark plugs are the resistive type. Take all this resistance plus the voltage drop on the systen due to cranking the engine into account and hey, no spark at all ! I changed the leads for copper cored (self made) and now the car starts while cranking instead of just firing as I turn of the key ! Brilliant. Resistive HT leads are such a pain; always cause trouble. I think the manufacturer goes all out to reduce emf emissions which works very well if I can't even start my car !
Here is how I made the copper cored HT leads. The problem is of course the fittings for the coil pack and spark plugs which cannot be bought. To get around this, use the fittings from the resistive HT leads. Chop the cable off right next to each fitting. Screw in a self-tapping screw (I used a 1 inch one) half way; then saw off the head of the screw; file or grind the end to a point and screw on the copper cored HT lead ( you can buy this from car accessory shop). When both ends have been assembled, I mixed up some araldite and applied around the join to seal it and strengthen it. I'm not sure araldite is the best stuff to use as it can crack up in cold weather. Maybe some silicon sealer would have been better.
I have noticed no interference on the car radio; although the leads are now copper cored, the plug caps and the plugs themselves are resistive so this helps with supression.
No New Posts Topic has attachmentsInterchangeable Gauge Cluster?
plug and play interchangeable clusters?
5 Erikgsi 73 5th January 2009 - 10:59 PM
Last post by: hoosieraccent
No New Posts Intermittant Engine Check Light
20 mickey taker 614 5th January 2009 - 02:33 AM
Last post by: dadel
No New Posts In Efforts To Keep The Peace
Street Racing Videos
2 v33sonata 65 4th January 2009 - 02:59 AM
Last post by: v33sonata
No New Posts Instrument Panel Lights
9 rcacs 110 23rd December 2008 - 05:00 PM
Last post by: mpattdu
No New Posts Instrument Panel Won't Light
Bulbs OK but white background not lit
3 iawia 429 19th December 2008 - 01:37 PM
Last post by: rcacs
7th January 2009 - 09:08 AM
