> Oil Pan Leak?, Possible Dented/Mangled from road damage
CheekyMonkey723
post Jul 10 2008, 02:31 PM
Drives: 2002 Hyundai Accent 1.6
The car was given to me from a friend, it wasn't well maintained, has 170,000 miles and some problems.
The girl who owned it lived on a street with a dip at the end and it would regularly catch somewhere under the car and make a horrible noise. The car leaks oil in the front when parked (in several different places). I believe it may be that the oil pan is badly dented or even slightly punctured, is that possible? Is it expensive to buy a new one, or hard to replace it? Without looking at it personally I'm assuming it can't be that hard and that oil pans can't be that expensive. But what if the new oil pan won't fit onto the old part that it goes on to (no idea what it's called) because it too is dented?
Any insight?
bowsercake
post Aug 2 2008, 02:26 AM
Drives: 1990 Toyota Supra Turbo
Oil pans can get dented, but in most cars the chassis is lower than it, so it should not hit.
A common place to leak is from the valve cover gasket, or from the crank or cam seals.
Valve Cover Gasket = oil in spark plug holes, oil on the top of the engine on the head, or near the injectors.
Cam Seal = Leaks near the top on the engine in the front, remove the timing cover to see.
Crank Seal = leaks near the bottom of the engine on the front. Its much harder to remove the timing belt cover but it will leak out near the oil pan
Oil Pan = should only be leaking on the pan itself, if there is oil above the pan then it check the other stuff.
Changing the oil pan is relatively hard and will require some time. I've never done it on a Hyundai but you might have to remove the front crossmember, I am not sure. But I would definitely check the other leaks first.
No New Posts Topic has attachmentsOil Leak
Oil pooling on transaxle
4 vctr 58 Yesterday, 04:46 PM
Last post by: vctr
No New Posts Topic has attachmentsOil Change Intervals For Canadians
When should you change the oil
13 jaymyson 327 28th December 2008 - 08:12 AM
Last post by: Don67
No New Posts Topic has attachmentsOil Drops Below $68 A Barrel.
Iraqi official: $100 a barrel is 'fair'
17 MiamiLX 218 25th December 2008 - 05:38 AM
Last post by: lovemysantafe
No New Posts Oil Change And Filter?
5 mckerr 134 24th December 2008 - 01:39 PM
Last post by: wtnlvr
No New Posts Oil Pan Heat Pad
5X7 Moroso 400W
4 James51 80 18th December 2008 - 09:13 PM
Last post by: James51
6th January 2009 - 02:46 PM
