 Hyundai-Forums.com > Hyundai Models > Elantra & Lantra Forum > 2G (1996-2000) Elantra & Lantra
> Tightening Belts 1998 Lantra Sportswagon, Need a bit of a walk through
Averilp
post Jul 11 2008, 05:53 PM
Drives: 1996 Hyundai Lantra (1998 motor)
Hi all,
After searching this forum, I believe that the horrible squealing we've started getting when we start the car (and sometimes on full lock too) is to do with the belts needing tightening.
My girlfriend has just been working night-shift and I don't think she'd appreciate being woken (again) by the car screeching like a banshee so...
Before I go running off to the mechanic and give him a weeks wages just to fix that, I thought I might see if anyone can give me a guided walkthrough of how to try this myself :) . Keeping in mind that this gal only knows the basics about cars...
Thanks in advance!
Averil
Lantraboi
post Jul 22 2008, 08:18 PM
Drives: 1996 Hyundai Lantra GLS
Hi there..There should be a adjusting bolt near the alternator. You will need to adjuct that outwards to tighten the belt. I'll have a look on mine to tell you exactly where it is...A quick fix is spray some WD40 or silicon spray on the belt while engine is running..this will stop the noise temporarily.
peachferrari
post Aug 1 2008, 12:42 PM
Drives: 1999 Elantra 2.0 L4; 2005 Tiburon SE 2.7 V6
First you'll need to figure out which belt it is--the Elantra has 3. If it happens with steering, my guess would be the power steering pump belt, which is the easiest to get to, it's the top one. To tighten it you'll need to loosen the 2 bolts on the power steering pump itself, then move the pump out to tighten the belt and tighten the bolts back up.
Yes a spray can temporarily help, but don't go spraying oil or something else on it--which will probably make it slip even more. Get a can of Belt Dressing, which is made specifically for this.
stevenk
post Aug 11 2008, 09:39 PM
Drives: Elantra 1998 1.8
I think there are three adjusting points in Elantra: one for AC, one for alternator and one for power steering pump. For AC driving belt, you need to go under the card and remove a shield to get there. Belt tension is very important. If the belts are old or damaged, you should replace that. I do recommend to replace all three belts at the same time as required. I bought those from online parts store they are not expensive! Take a look your car carefully to find out which belts and where the adjusting points are located. After that, if you feel you can't make it you better bring the car to the mechanic shop for saving your time and safety.
No New Posts Lantra 95 M Reg Auto Transmission Slips
Auto gears not engaging from stop
2 drjohnwilliams 230 28th November 2008 - 12:50 AM
Last post by: Madogi
No New Posts Topic has attachmentsLantra/elantra Fuel Consumption
Lower consumption
15 marek46 1,249 5th November 2008 - 02:22 PM
Last post by: marek46
No New Posts 1998 Excel Glx Help please
1998 excel glx help please
0 Finwe 30 4th November 2008 - 02:43 AM
Last post by: Finwe
No New Posts 1998 Atoz Wont Start
1 ericatwork 532 20th October 2008 - 12:17 PM
Last post by: Hyundaiownersclub
No New Posts 1998 Hyundai Accent Car Trouble Help!
stalling help
1 icey14 266 19th October 2008 - 06:50 PM
Last post by: icey14
6th January 2009 - 05:04 PM
