 Hyundai-Forums.com > Hyundai Models > Tiburon Forum > GK Tiburon (2003-2008)
> Grinds 3rd, bad tranny?
chad_mac
post Jul 15 2008, 06:38 AM
Drives: 2003 Tiburon Tuscani 2.7 V6
seem when i shift into 3rd at a higher rpm it will grind going in but if i let the rpm drop a bit it will go in no problem what would cause this? clutch?...tranny?
terkar
post Jul 15 2008, 09:06 AM
Expert
Drives: 2009 mercury milan, 2007 Santa Fe limited, and 2009 Mustang
time to replace clutch and flywheel
byronguidry3732
post Jul 15 2008, 10:46 AM
Group Icon
Group: Super Mod
Drives: 2003 Tiburon GT 2.7, 2004 Santa FE FWD 2.7, 2001 Sonata 2.4, 1984 Pontiac Fiero SE
Dear chad,
Could be as terkar says but let's complete a diagnosis:
a) Do you have grinding in any other gear, including reverse?
B) What color is your hydraulic fluid in the clutch master cylinder reservoir? How old? If black and don't know, you might try replacing the fluid by bleeding through the slave cylinder nipple.
c) Have a friend depress and release the clutch of the car shile shifting through the gears with engine stopped, and you observing with your head under the hood. Does the clutch fork mechanism appear to move smoothly back and forth for each shift?
d) Have you checked your clutch pedal travel per the owner's manual?? Is the point of engagement quite low? Your clutch should fully release after 3.5 (from memory) inches of travel, but be fully engaged/no slip 1 inch from the top of your release stroke.
Sounds to me like you don't have a skipping clutch (indicates high wear) but a failure to disengage (opposite problem grips too much).
After eliminating clutch issues, you may be left with a transmission problem but that is part of the 60,000 mile warranty. If you are very close to breaking 60k miles, stop driving the car until you get it to a dealer for evaluation.
Byron
peachferrari
post Jul 15 2008, 04:00 PM
Drives: 1999 Elantra 2.0 L4; 2005 Tiburon SE 2.7 V6
First, define "grinding"--could be the syncros or the clutch/flywheel, but you probably don't need a new one.
If it's only 3rd gear, it's more likely the syncros than anything, which are known to be fairly touchy on 2nd and 3rd gears, at least on the 6-speed. For me a new set of linkage bushings helped a lot. You can get some from Kartboy.com (though I don't know if his site lists them for the Evo (same as the Tib) anymore) or from KJBmotorsports.com
chad_mac
post Jul 16 2008, 06:34 AM
well it only does it going into 3rd, no other gear. and i dont really know how to define grinding...but it just has a quick grind going into 3rd at a higher rpm.
Bishop.519
post Jul 30 2008, 10:48 AM
Drives: 2003 Tiburon i4
i had a similar problem but mine was doing it in 2nd, i replaced the clutch and resurfaced the flywheel and i was good after that. Hope that helps
vpxdemon
post Jul 31 2008, 06:23 AM
Drives: Hyundai Tiburon 2005 GT
I have a 2005 automatic, and mine has a problem shifting into 3rd as well. It will rattle the whole car unless I lift off the gas just before it shifts. They replaced the transmission after 5K miles but that didn't solve the problem. They flashed the software on the shiftronix and it was fine for a year, until I reached across the car to grab something and knocked the car into manual shifting. I moved the shifter back over and it immediately went into the problem of shifting to third again.
I finally just gave up.
peachferrari
post Aug 1 2008, 12:21 PM
QUOTE(vpxdemon @ Jul 31 2008, 05:23 AM)
[right][snapback]179947[/snapback][/right]
That's really not the same problem though. Auto trannies don't have clutches or syncros, so it's not really related. That is a strange problem though, and sounds like it has something to do with the Shiftronic since it happens after you move it over there.
No New Posts 3rd Row Option
2007 vs. 2008
7 reemoe 175 25th December 2008 - 04:42 PM
Last post by: lovemysantafe
No New Posts 3rd Brake Light Rattle?
6 DarrenCax 107 4th December 2008 - 11:43 AM
Last post by: vpaloc09
No New Posts 3rd Brake Light Replacement
Should be easy right?? NOT!!!
5 Sonatanator 147 17th November 2008 - 03:40 PM
Last post by: dogstar
No New Posts 3rd Gear Clunk
4 nickpike 233 13th September 2008 - 08:10 PM
Last post by: nickpike
No New Posts 3rd Brake Light Housing - Removal
how to?
3 dd716ted 326 7th September 2008 - 05:33 PM
Last post by: MiamiLX
6th January 2009 - 12:42 AM
