QUOTE(trent clayton @ Jul 16 2008, 01:47 AM)
can you please tell me if the enginge in the 1999 is a zero clearence engine or not?my daughters car quit and all indications are its the belt.turns over with no resistance...like there is no compression.car has 150,000 turns on it and she was going down the road when it happened.the make is a elantra w/a 1.9 manual trans i just hope the engine is still good
[right][snapback]176493[/snapback][/right]
if you are talking about a broken timing belt, which l think you are, then it will have caused engine damage, it's almost certain you will have bent valves
