QUOTE(arnold @ Jul 16 2008, 05:39 PM)
Hi guys,
I hope you could share your inputs about my jet. It vibrates when applying the brakes and felt obviously coming from high speed while turning the steering wheel. it doesn't matter whether you turn left or right. Braking on a straight line, vibration is moderate. The brake pedal is not pulsating.
Any ideas?
[right][snapback]176547[/snapback][/right]
3 possibility,
1) Wheel not properly balance
2) Brake disc rotor warp
3) Wheel hub bend (if you go over pot holes at high speed)
