48k Service |
Jul 29 2008, 08:50 AM
Status:
Drives: -
you do not need to do a transmission flush for another 48 000 kms. The wheel alignment is for the sake of your tires mainly. A small amount can cause uneven wear or scalloping on your tires. You don't have to have this done at a Hyundai dealership, but keep records, and make sure after the alignment is done your steering wheel is straight, and there is no pull in either direction.
At 48 000 you should be having the brakes serviced, the calipers are a moving part and when they seize you are looking at doing your brakes (rotors and pads minimum), and there is no warranty on your calipers if they are not maintained.
This service also includes having your coolant replaced, this is not a flush it is a drain and replace, but the Hyundai coolant life is only good for 50 000 kms. Also the air cleaner filter needs to be checked, if it has been replaced recently it doesn't need to be changed. The rest of the service is inspection of the brakes, fuel lines, transaxle oil, exhaust, suspension mounting bolts, power steering, etc. Most of this is still covered under your warranty, and should take an hour to an hour and half to do. If you don't want to bother with the inspections, you should at least be getting tires rotated, oil change, coolant and possibly air filter change, as well as the brake service. Price these out individually, keep your receipts for work done. Skipping the "inspections" shouldn't void your warranty, but the mechanics should notice a wearing part and replace it before you start having trouble or get stranded. Especially in a province where there aren't annual safety inspections done on vehicle.
Aug 7 2008, 09:06 AM
Status:
Drives: 2007 Santa Fe 3.3GL
Thx guys, ya ill get oil change, brakes checked, alignment ( need one, my tires are wearing slightly on the insides) also may get cabin filter done. Only thing is i have free oil changes, but apparently this is only honored at my dealer, that being said ill get rest of stuff done, then maybe call dealer for oil change only :thumbsup:
Aug 7 2008, 10:29 AM
Group: Super Mod
Status:
Drives: 2003 Tiburon GT 2.7, 2004 Santa FE FWD 2.7, 2001 Sonata 2.4, 1984 Pontiac Fiero SE
Dear Santa,
For US delivered Hyundai Santa Fe's, we get a Scheduled Maintenance table in our owner's manual towards the back of the manual. These are the required services to comply with the normal maintenance requirements to keep your warranty in effect.
This does not preclude the service writers at the US Hyundai dealerships from telling us that the transmission flush is 'good for the vehicle' or 'make your transmission last longer' or even thinly veiled threats on our warranty. I bring in the owner's manual every time and challenge these up-sell attempts. Pulling out the manual and challenging the service writer to show you in the book is a very effective technique to shut down bogus up-selling.
A lot of the service you are getting charged for is inspecting: hoses(check) belts(check) leaks (check) Fluid levels (check) suspension travel (check) ...mostly things that you could do yourself or at a non-Hyundai shop for far cheaper. To keep your warranty valid in the US, you merely need to keep the receipts showing the service was performed, or receipts (dated) for items like air filters, oil filters, oil changes, even transmission flushes.
One word of warning: Your Santa Fe really prefers that SP-III transmission fluid, and hates almost everything else with the the exception of Castrol ATF+4. IF you get a transmission fluid flush outside the dealer, make sure you verify what type of fluid the shop is installing and that it meets or exceeds Hyundai SP-III standards.
Byron
Similar Topics
Similar Topics
