I would contact someone, maybe an electrician, that would have a clamp on DC Ammeter. You can check around and buy on if you like. Check how many amps are being drawn on the battery cable with the car off. If it is excessive (might want to compare to another similar vehicle) you can pull fuses one at a time and find the cause.
Edit: I am assuming that this issue is happening only when you go to start the car that the battery is dead. It seems like something is using the battery up when the car is off. Is the car dying after it is running and then not turning over? If so, this sounds like the alternator. You would think there would be a light on the dash to let you know. Could also be a corroded or loose cable that is conducting with little load, but causing a big drop when starting or trying to charge a dead battery. Might want to check the battery voltage with a multimeter on the battery posts when the car is off, starting & running. May want to check AC volts when running, should be very little. Might be over 0.5 volts if a diode is bad.
Just my ideas. Electrical issues with cars do not follow normal electrical theories, LOL.
This post has been edited by Traveler62: Aug 3 2008, 09:03 PM
