 Hyundai-Forums.com > Hyundai Models > Getz Forum
> Getz Steering Problem, Rattling Sound and Stiffness in Steering
Getz Lover
post Aug 1 2008, 12:03 PM
Drives: 2006 Hyundai Getz 1.1M
Help a damsel in distress! There is a "rattling" sound that seems to come from the front in my Getz 1.1. The steering appears to be stiff with noise at low speed or stationary. What is the likely cause?
Getz Lover
1.1M
53000 mileage
Bought Jan 2006
montego
post Aug 1 2008, 12:15 PM
GLOBAL MODERATOR
Group Icon
Group: Super Mod
Drives: XG's (2001&2002)
check the oil level in the pwer steering resovour it sounds as though it may be low on fluid (you may have a leak)
dingerbell
post Aug 22 2008, 01:23 PM
Drives: 2003 Hyundai Getz 1.6 Sport
Hi...As the other guy said...check the steering fluid level first, and if low add some.
Also at the same time, check the belt tension, which you will easily see...reach in and press in the centre of the belt, and if it moves more than 1 [one] inch then it needs tightening [had the same problem with mine Getz 1.6 Sport after a long run].
There are two bolts you need to loosen [12mm spanner required].
They are easy to see and get to, one is on the bottom of the pump, and the other is at the top [on a swing arm].
Once loose you will need a bar at the back of the pump to pull towards you and so tighten the belt, and while holding the tension tighten the bolt on the top.
Check the tension, and the belt now when pushed in the middle should move about 1/2 [half] an inch.
If so, then tighten the bottom bolt, recheck the tightness of the top bolt again, finally checking again the bottom bolt...and thats it done!!!
Good luck - Am sure you will be able to do this and fix it.
No New Posts Problem With Brakes
(abs)
9 timmy wimmy 84 28th November 2008 - 08:33 PM
Last post by: liquid_02
No new Topic has attachmentsSteering Wheel Controls
update
89 error666 4,710 23rd November 2008 - 03:57 AM
Last post by: dogstar
4 Osaka 193 17th November 2008 - 09:24 PM
Last post by: mrstats
No New Posts Steering Squeaks
0 yepsee 15 15th November 2008 - 02:17 PM
Last post by: yepsee
No New Posts Getz Assessories For Sale
1 Maxpsi 218 14th November 2008 - 03:44 AM
Last post by: blackbullet
2nd December 2008 - 09:48 AM
