hello, first my english is a litle bad, i am french canadien. I turboed my accent 2006(lc2) My stock list:
1.6L turbo kkk03 set at 7psi bov intercooler home made simple AFC(when boost occur computer see O2 sensor very lean an enrich mixture at aprox 12-13:1..it's work good) home made return line FMU 6:1 and FPR
i have probleme when boosting but not allways, the car hesitate or not give me the full power...is very strange...first, when a snap the trottle in the floor, i feel the power but after one or 2 second, the car buck 1 or 2 second and i don't feel the power after but boost is at 7psi, if i release the trottle for less boost 2-4 psi at max..i feel the power...
my problem occur whitout my home made cheap AFC(But the buckage is less strong with my cheap AFC) ... i think is probably my map read too much pressure and cut the fuel but i have read in this forum the stock ECU and Stock map do not cut fuel above 14.5psi of boost?!?!
Assumption : 1-Map cut fuel 2-I don'T have tried to run a colder sparkplug, i run my stock sparkplug...?! 3-Timming/compression to advanced/high
all helps is apreciated thanks...and very sorry for my limited english!
