 Hyundai-Forums.com > Hyundai Models > Tiburon Forum > GK Tiburon (2003-2008)
> Combustion Problems
leoneingabbia76
post Aug 9 2008, 11:54 AM
Drives: 2003 Hyundai Tuscani 2.7 V6
Hi I'm new here but I appreciate very much all your useful information. I have a problem with my tuscani 2.7 V6 year 2003 and I was hoping you could give me some advice if perhaps you had the same problem.
When I start the engine after a few seconds I start hearing some kind of "explosions" from the muffler or the exhaust tube. It goes on for some seconds then there's a final "explosion" louder than the others and the noise stops. When I turn off the engine after a while (the engine is warm) the noise starts again, with the engine off. It's not the ticking of the thermal expansions it's a sound like of uncombusted fuel that reaches hot surfaces and explodes. Have you ever had this problem and most of all what can it be? Thanks for your help
peachferrari
post Aug 12 2008, 04:20 PM
Drives: 1999 Elantra 2.0 L4; 2005 Tiburon SE 2.7 V6
That might be exactly what it is--unburned fuel getting into the exhaust system and exploding there. Could be a problem with the injectors or valves, letting fuel leak when it shouldn't. Could also happen if you are running too rich of a fuel mixture, though that wouldn't explain it happening after shutting the car off.
I'd get it checked out soon though, because if fuel is getting into the exhaust it could cause problems with your catalytic converter overheating.
leoneingabbia76
post Aug 13 2008, 07:40 AM
Thanks!
I'm having the car checked on the 4th of September but my fear is that the mechanic will tell me it's nothing and let me go.I want to get to the appointment prepared.
Do you think it could be the purge control solenoid valve that perhaps is not closing well?
I'm also having another problem lately: it seems to me the car is more nervous(as regards injection) meaning that when I press the accelerator and release it the car has a sort of nervous reaction. Also when I'm decelerating with the gear inserted after a few seconds I hear a sort of a tug with the car "jumping" forward. I don't know if it's a problem of injectors(it only happens decelarating) or if it's a problem of spark or wires.Any idea is appreciated, thanks again
byronguidry3732
post Aug 19 2008, 02:21 PM
Group Icon
Group: Super Mod
Dear leon from Italy,
Every symtpom you are describing will cause a Check Engine Light (also called a Malfunction Indicator Light). This is the yellow silouhette of an engine block on the dashboard. Please get your Check Engine Light codes read at an automotive shop. This will tell you what is wrong...and the Tuscani computer will give you a code from just one misfire.
Byron
leoneingabbia76
post Aug 20 2008, 12:25 PM
Hi Byron, thanks for the advice. I had once(few months ago when I already had the "combustion" problem) the check light switch to on and I took the car to the shop. They did their checks and eventually said it was one of the oxygen sensors that was not working properly. They changed it and the light went off but I still had the same noise/problem.
I'm going to force the mechanic fix this because I don't want to end up with major problems later.
Igor
post Sep 25 2008, 07:01 PM
Drives: 2003 tib 2.0
If catalytic converter is polluted it can stops the air flow inside exhaust, so you can hear big bang when is released.
You can also hear rattling noise if catalytic converter got separated from the outer casing.
That can be one type of possible problems.
This post has been edited by Igor: Sep 25 2008, 07:02 PM
No New Posts Problems....problems...and Mo' Problems....
My baby is hurtin!
4 otisflick 499 2nd September 2008 - 04:24 PM
Last post by: meltedsilver
No New Posts Topic has attachmentsProblems With Navigation System
7 WeirdMetamorphosis 285 2nd September 2008 - 01:08 AM
Last post by: DarrenCax
No New Posts Problems Putting Gas In Santa Fe 2002
Pump nozzle keep turning off
5 greyreefshark 276 26th June 2008 - 08:35 PM
Last post by: greyreefshark
No New Posts Problems With 03 Tiburon
2 Notworthit 373 26th June 2008 - 07:52 PM
Last post by: Notworthit
No New Posts Problems With Rear Brakes! Help!
Drivers rear brake not engaging
3 jaymyson 423 24th May 2008 - 03:43 AM
Last post by: gerald2003r
2nd December 2008 - 10:43 AM
