QUOTE (Don67 @ Nov 25 2008, 02:55 PM)
The constant ticking is likely normal fuel injector noise, as saraph says, and subtle cold-weather knocking noises are probably just subtle cold weather knocking noises. If you suspect something worse, have a mechanic listen to it. There is a certain danger in taking advice from well-meaning strangers over the internet who cannot hear your car running.
I would never dump additives into a newer engine just to make it run quieter, in fact even Hyundai advises against this. Anything that stifles normal engine noise is either very thick or is leaving a coating behind that can only clog things up in the long run.
'Don67',
Excellent advice. If Hyundai believed additives would help their engines, they would be installed at the factory.
An engine that is in good condition, should never have lifter noise that go away after a quarter of a mile or so. Also, temps at or around freezing should not affect an engine in any way. Now, if we are talking about sub zero temps, that is an entirely different matter. Then you will be lucky to get the darn thing started. (IMG:
style_emoticons/default/grin.gif)
I strongly urge anyone with a relatively new engine that is knocking or better said, "clattering", for any length of time, to take into the dealership and keep your warranty, and vehicle safe.
David <><
