I had my oil changed today. My car needed a "lot" of tramsmission fluid. The mechanic said I had a front axle leak. I figure I'm under the 100,000 mile warranty; however, before I proceed I want to make sure it's not my fault. Last year my granddaughter went into a ditch with my car. It was turned on it side and all the transmission fluid poured out. the mechanic who did the body work said there were no problems with the transmission. It just poured out due to the position of the car. The car needs a front end alignment that I have been putting off. Given the above info why is my front axle leaking? Thank You :liebe011:
