I own a 2001 Sante Fe and have had ongoing problems with what appears to be premature corrosion. At this point I have replaced all the power steering lines and now need to replace all my brake lines due to corrosion at a cost of over $1000.
I live in Canada where salt is used however I am meticulous in undercoating my vehicle annually to ward of off corrosion.
I have noticed from posts on the forum others have experienced power steering line corrosion in geographical areas in which salt is not used on roads. I am left to question if Hyundai has used inferior quality steel in the producrion of metal lines carrying fluids such as power steering and brake fluid.
Have any other members had problems with brake lines corroding?????
Thank You
Thank You
