I have a 97 tiburon and its not shifting into overdrive. I've heard it could be an overdrive solenoid but im not sure. Does anyone have any advice on what it might be?
so i check all the wiring and try it and i had no luck it all appears to be good condition and i test drove it still wont engage to overdrive. what do you think my next step is from here??? drop the pan and check da silenoid or do a flush... ??? let me know thanksIt is possible it is a Shift Solenoid, But I would take a look at the switch on your shifter
I have seen were the wire under the shifter get pinched I left a picture below. Hope this
helps.
Shawn
yeah i hear you. well im gona try that have it check and if it turns out the trany is bad ima go head and go for it after all i already did a headgastket on it. it cant be that badI have had the same issue with my 2000 tib, I bought it like that but only paid 1200.
I changed the pulse generator, flushed the trans ( big mistake DO NOT FLUSH THE TRANS). A trans flush can make it worse. Most places do a reverse flush and it can ruin the transmission. This is what I have been told by multiple mechanics.
New shift knob with the o/d control, checked wiring, even replaced the ecu and trans computer. Turns out bad TRANS.
From what I have read the AUTO trans is terrible in these cars. After the fact, I found out the bad trans I have is the 3rd one in the car.
I only use it for work and rarely go over 50mph in it, so it doesn't really effect me I turn the o/d off so it doesnt try to shift into the high gear.
Before dropping money into it and trying to track down the problem, take it to a legit Trans place and have them look at it. I dont have the time or money to worry about mine right now, but it also might be cheaper to find one from a junk yard and replace it, but you never know if it is good.
I hope this helps as I spent a year and a couple hundred dollars trying to figure this out. Don't want to see anyone go through the same as me.
Good Luck
